MERGE node downstream of an IF node - Need Help
Hi,
Sorry to hijack this discussion.
You must change you API keys immediatly.
Just tried a “GET” request with the key available in this workflow, and it’s working.
I’m sure it’s a mistake, but kind reminder to never share your API keys publicly!
Cheers
PS: and for this issue, it seems that the evaluation is made only when the full workflow is launched, not a single node, I’m struggling with this too!
Thanks, just changed it.
You’re welcome.
But unfortunately you should revoke and generate a new key, deleting the post won’t delete the data already crawled by bots.
I just tried the call again, it’s still working.
