Merge Node inside Loop Noode for dig data merge
Hi,
    Running version [email protected]
    default: SQLite (I can change if needed)
    default
    n8n cloud
    windows
I have 2 different sources
  • orders : between 10 and 20 thousand rows
  • hs_codes : 34 thousands row
orders columns
  • NUMBER
  • HS_CODE
  • other columns (10 in total)
hs_codes columns
  • hs_code
  • complementary_unit
  • prohibited_h7
I need to have an output of hs_codes columns added to the orders.
I tried multiple things. For now, I have a Postgre not that makes a select from the hs_codes to get only the ones in the orders.
When I do a simple Merge Node, I have an error because the data is to huge.
When I try to do a loop (I dit with batch of 100 / 200 and now 1000). I have everything demultiplicated (I tried with an 8000 rowas) :
I am not sure of my approach. If you have any idea of fhat could be done better?
I just updated the required information
I found the appropriate method:
Aggregate before doing the Query to the postgre.
Use a Query with SELECT … IN …
