Description:
The Merge node in SQL Query mode intermittently returns “No output data returned” and halts the workflow, despite identical inputs and logic that worked reliably until recently.
Key observations:
All upstream nodes execute successfully
Inputs still contain data
The SQL query executes without error
The node returns zero rows, even though it previously returned valid results with the same logic
Removing the where clause or simplifying joins sometimes produces output, suggesting a behavior change rather than a query syntax issue
Expected behavior:
Input data shape is unchanged
Join keys are present
Filters match existing rows
Behavior should be consistent across versions or documented if changed
Actual behavior:
Merge node outputs no data
Workflow stops execution
No warnings or errors indicating why rows were filtered out
Same data and logic previously worked
