Disclosure: I build SusLabs Reddit Scraper & Monitor, the paid data source used here. This guide was prepared with AI assistance and real workflow execution checks.
Reddit has scheduled RSS shutdown for 13 November 2026. For workflows that currently read those feeds, I prepared two inactive n8n examples:
- RSS-style monitoring → title/link mapping → optional Slack or Sheets destination.
- The same flow with a phrase-based intent threshold before the destination.
The important migration work is the input/output contract. Replace RSS Read with an HTTP Request that starts a bounded read-only monitor; keep a stable monitorName and source scope; map title, permalink, subreddit and createdAt explicitly. Do not assume a feed’s GUID and the new dataset’s item ID are interchangeable.
Start manually with one subreddit and a small item cap. Check a first run and an immediate repeat, then inspect SUMMARY for failed sources or possible gaps. Empty successful output should not be confused with an interrupted collection. A remote timeout also deserves a status check before restarting the Actor.
The templates import inactive, contain no working credentials, and keep Slack/Sheets nodes disabled. Configure your own Header Auth credential for Apify; remove the placeholder Authorization header. Connect destinations and test them manually before adding a schedule.
Both workflows were imported and executed with local n8n 2.22.6 against the live Actor on 22 October 2026. Proof inputs used one subreddit and eight-item caps. A private HTTP receiver checked the mapped output; actual Slack and Google Sheets connections were not exercised. The separate real RSS-URL demo returned four NEW posts and zero NEW on repeat.
The data source is paid: Free-plan fixed fees checked 22 October are $0.003 per start at default memory and $0.0015 per successful source, before items. Public website changes can affect availability. It does not handle Reddit write or moderation operations.
RSS task: Reddit RSS Feed Replacement — Export Subreddit Posts · Apify
Reddit source: https://support.reddithelp.com/hc/en-us/articles/54353370049684-Changelog-October-8-2026
Download or import the inactive workflows:
In n8n, paste either URL into Import from URL, or download it and choose Import from File. Both anonymous downloads match the reviewed copies byte-for-byte, as checked on 22 October 2026. Configure your own credentials and keep the workflow inactive during setup.
