~/.n8n $ n8n import:entities --inputDir=./outputs/ --truncateTables
Error tracking disabled because this release is older than 6 weeks.
This feature is currently under development.
Starting entity import…
Input directory: ./outputs/
Truncate tables: true
Found entities.zip file, decompressing to ./outputs/…
Successfully decompressed entities.zip
Latest migration in import data: DropUnusedChatHubColumns1760965142113 (timestamp: 1760965142113, id: 103)
Latest migration in target database: DropUnusedChatHubColumns1760965142113 (timestamp: 1760965142113, id: 106)
Error importing entities. See log messages for details.
Error details:
Migration ID mismatch. Import data: DropUnusedChatHubColumns1760965142113 (id: 103) does not match target database DropUnusedChatHubColumns1760965142113 (id: 106). Cannot import data from different migration states.
My current setup is:
- Docker with SQLite, N8N version. 1.117.2
What i am trying to do is, migration everything from this docker to k8s and deploy it with postgresql. I have setup the n8n and postgres instance in k8s, but when i export entities from my old setup, & import it to this new one. I get above error. The image using in docker and k8s are the same.
