Hi! I’m trying to build a custom node using n8n-node-dev on Windows 10, but I’m getting the below error. Looks like it’s trying to run the shell script for tsc in nodejs? Any ideas?
>n8n-node-dev build
Build credentials and nodes
The nodes got build and saved into the following folder:
C:\Users\user\.n8n\custom
C:\Users\user\AppData\Roaming\npm\node_modules\n8n-node-dev\node_modules\.bin\tsc:2
basedir=$(dirname "$(echo "$0" | sed -e 's,\\,/,g')")
SyntaxError: missing ) after argument list
at wrapSafe (internal/modules/cjs/loader.js:1054:16)
at Module._compile (internal/modules/cjs/loader.js:1102:27)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1158:10)
at Module.load (internal/modules/cjs/loader.js:986:32)
at Function.Module._load (internal/modules/cjs/loader.js:879:14)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
at internal/main/run_main_module.js:17:47
