Model output doesn't fit required format
When using a output parser in llm chain using gamma 4 model getting this everytime
@Mukul_Rai that error means the parser couldnt validate the models text as json matching your schema, and smaller models trip on it constantly, they wrap the json in prose or markdown or drop fields. two fixes, easiest is wrap it in the Auto-fixing Output Parser, it runs a second llm pass to repair the output before parsing. the more reliable one is switch to a model thats solid at structured output (gemini flash, gpt-4o-mini, claude haiku), weaker models just cant hold the schema. and tighten the prompt to say return only valid json, no markdown or extra text.
@Mukul_Rai
This is expected, gemma 4 schema does not conform to Open AI format. If you self-host, you might still be able to proxy it through LiteLLM
This error comes from the structured/output parser doing a strict schema check on the model’s response — and the response not matching (usually extra prose, markdown ```json fences, or slightly malformed JSON). The “change On Error in the root node” hint just stops it from failing the run; it doesn’t fix the actual output, so I’d treat that as a last resort, not the fix.
The real driver here is almost certainly the model. If “gamma 4” is Google’s Gemma running locally, smaller open models are notoriously weak at strict structured output and function-calling compared to GPT-4o / Claude — they tend to wrap JSON in code fences or add explanation text, which breaks the parser every time. A few things that fix this, in order of impact:
  1. Wrap it in the Auto-fixing Output Parser. n8n has a parser that, when the first parse fails, automatically feeds the bad output plus the error back to the model and asks it to correct the format. This alone fixes most weaker-model cases — biggest win for the least effort.
  2. Tighten the prompt. Explicitly tell the model: “Return ONLY valid JSON matching the schema — no markdown, no code fences, no explanation.” Small models love to add code fences and prose; saying this plainly removes most of the failures.
  3. Drop the temperature to 0-0.2 for the structured step. Higher temperature increases format drift.
  4. Simplify the schema. Deeply nested objects with many required fields fail far more on small models. Flatten it, keep required fields minimal, and add a short description to each field so the model knows exactly what to produce.
  5. If accuracy matters and you can, use a model that’s stronger at JSON / tool-calling for the parsing step — even another local one like qwen2.5-instruct handles structured output much better than Gemma in my experience, and an API model (a small GPT-4o-mini or Claude Haiku) gets you near-100% compliance.
I’ve hit this exact thing running local models for structured extraction — the auto-fixing parser plus an explicit “JSON only, no fences” instruction usually takes it from failing every time to reliable. Start there and see how far it gets you.
The parser/auto-fix advice above is right. I would also treat this as a monitoring problem, not just a prompt problem.
In production, an AI step that sometimes returns the wrong shape should not be allowed to continue as if the workflow succeeded. I would put a validation gate immediately after the model step:
  1. Check that the response is valid JSON.
  2. Check all required fields exist.
  3. Check fields are non-empty and within expected ranges.
  4. Route invalid output to retry, auto-fix, or manual review.
  5. Log the validation result with the execution ID and input type.
The key distinction is technical success versus business success. The workflow can finish green while the output is unusable. For client workflows, I would want those validation failures to become visible issues, because otherwise the client only notices later when bad data reaches a CRM, email, sheet, or report.
