Monday.com node issue
After a recent update (You’re on 1.14.2, which was released 2 months ago) I’ve started experiencing a Monday.com issue. The node itself stopped show its output, and now in order to see the output I have to use the Edit Fields (used to be Set) node, which is really inconvenient because now I have to use two nodes instead of one.
Could you please advise me on how to overcome this bug?
  • n8n version: 1.14.2
  • Operating system: Linux
No one experiencing the same problem? Like at all?
Hi @Sergiy_B, welcome to the community and sorry for the trouble.
It sounds like you have encountered the problem raised here. Can you upgrade to n8n 1.21.0 (or later)? This version comes with a fix for the problem.
Please do let me know if you’re still running into this problem after upgrading.
