MongoDB Update - Need help with expression syntax
I need to update a simple description field in MongoDB based on the _id but the record never gets updated.
Method: Update
Update key:
{ "_id": "{{ $('MongoDB').item.json._id }}" }
Fields:
{"description":"text"}
No error message. The process completes successfully but the record is not updated
  • n8n version: [email protected]
  • Database MongoDB:
  • Running n8n via n8n cloud
  • Operating system: Mac
The fields where you have entered raw MongoDB query syntax are only looking for a name or list of names to reference from the input item. The node wraps everything up internally into MongoDB query syntax for you. This is how it is supposed to work:
Thank you! Problem solved.
