This issue is similar to the other MS SQL Node problems in my earlier thread.
When I have a Boolean value I get the following SQL Error:
Invalid column name 'true’
This can be corrected by converting True to a value of 1 and False to a value of 0. This way we can use the BIT data type in SQL Server without a problem.
