I’m creating a workflow for follow-up, and this workflow is supposed to perform a getCards in 9 Trello lists in parallel to send a message to one person from each list, and this was working fine! However, at some point, I saw the opportunity to configure it so that when one of the lists returns empty, it waits 5 minutes and runs the getCards of the next list again to send a message to a new person.
After configuring and testing the workflow, I realized that instead of running each getCards in parallel, the workflow was running the entire queue of one getCards before checking the getCards for the next list.
With that, my question is: will it always run this way, or is this a bug in the test? If it always runs like this, is there a way to work around it?
<your workflow>
It is expected behaviour. If you have a set (list) of items n8n will process them sequentially, one by one, unles I misunderstood what you mean by “parallel”.
