My gmail node is not working. i started using n8n then went to try hostinger, didnt like it and came back to n8n and ever since i cant login to my gmail node please help
my gmail node is not working. i started using n8n then went to try hostinger, didnt like it and came back to n8n and ever since i cant login to my gmail node please help
So you’re running your workflow in n8n cloud right now?
And I assume that you’ve copied it over from a previous selfhosted instance on hostinger?
In this case…have you tried to delete the credentials and setting them up again?
What is your current error message when using the node?
Try to add a new gmail node in a new workflow and test it there. If this works, you might want to delete the gmail action from the workflow, copy the whole thing to a new workflow and add a new gmail action there - hope it helps!
