My workflow is gone 404 - What is the correct way to ask for help?
@Niklas_Hatje
Good evening, how are you? So, my workflow was published but it’s showing a 404 error (not found)! Can you check it?
https://n8n.io/workflows/?q=Integrating%20AI%20with%20Open-Meteo%20API%20for%20Enhanced%20Weather%20Forecasting
https://n8n.io/workflows/2692-integrating-ai-with-open-meteo-api-for-enhanced-weather-forecasting/
Hey @frkr,
we had an issue with our site not correctly. That should now be solved, can you confirm?
