It appears the course n8n102 is desiged to make the learnerns suffer, first it has a bug in section 1 on SendToPriorityQueue which is yet to be resolved, and now the Webhook part just cannot be followed as the testing page requires https whereas the tutorial uses http, so again stuck big time right at start of hands on excercize here is the json/workflow error screenshot is:
“nodes”: [
“parameters”: {
“httpMethod”: “POST”,
“path”: “course/n8n102/new-order”,
“authentication”: “headerAuth”,
“responseMode”: “responseNode”,
“options”: {
“allowedOrigins”: “*”
“type”: “n8n-nodes-base.webhook”,
“typeVersion”: 2.1,
“position”: [
0,
0
“id”: “5b647ab0-18c4-41a4-bb01-62fddb40e0d7”,
“name”: “WebhookNewOrder”,
“webhookId”: “cb64f5fc-8c9c-4d7d-abb7-7f3ca5eb7305”,
“credentials”: {
“httpHeaderAuth”: {
“id”: “vMHAPkPKaravjcEZ”,
“name”: “n8n Academy API Key”
“parameters”: {
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: “”,
“typeValidation”: “strict”,
“version”: 3
“conditions”: [
“id”: “dd887f0b-a710-4f6d-ae7b-4135da5667a8”,
“leftValue”: “={{ $json.body.order_id }}”,
“rightValue”: “”,
“operator”: {
“type”: “string”,
“operation”: “notEmpty”,
“singleValue”: true
“id”: “a7140c1e-23cc-4dba-9662-0059886cdb53”,
“leftValue”: “={{ $json.body.customer_id }}”,
“rightValue”: “”,
“operator”: {
“type”: “string”,
“singleValue”: true
“id”: “438dee60-5bcf-4002-927e-280813e11b18”,
“leftValue”: “={{ $json.body.total }}”,
“rightValue”: “”,
“operator”: {
“type”: “number”,
“singleValue”: true
“combinator”: “and”
“options”: {}
“type”: “n8n-nodes-base.if”,
“typeVersion”: 2.3,
“position”: [
208,
0
“id”: “9fb45b77-fe7c-4240-848b-deadf5cf8bc7”,
“name”: “ValidateRequiredFields”
“parameters”: {
“respondWith”: “json”,
“responseBody”: “={\n “status”: “accepted”,\n “order_id”: “{{ $(‘WebhookNewOrder’).item.json.body.order_id }}”,\n “message”: “Order received and queued for processing”\n}”,
“options”: {
“responseCode”: 200
“type”: “n8n-nodes-base.respondToWebhook”,
“typeVersion”: 1.5,
“position”: [
416,
-96
“id”: “b945dafb-6e2f-461a-8534-414b735b7ab8”,
“name”: “RespondSuccess”
“parameters”: {
“responseBody”: “={\n “status”: “error”,\n “message”: “Missing required fields: order_id, customer_id, and total are required”\n}”,
“options”: {
“responseCode”: 400
“typeVersion”: 1.5,
“position”: [
416,
96
“id”: “b23fadc8-b731-444d-bc84-10cb1f7d9f38”,
“name”: “RespondValidationError”
“connections”: {
“WebhookNewOrder”: {
“main”: [
“node”: “ValidateRequiredFields”,
“type”: “main”,
“index”: 0
“ValidateRequiredFields”: {
“main”: [
“node”: “RespondSuccess”,
“type”: “main”,
“index”: 0
“node”: “RespondValidationError”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “1b202188b62737e64678f469a8e86b98e8d2c2147255e95f1e4af4dc019b5e9d”
