N8n Academy Quickstart "Generating reports: Retrieving order data" stuck
Hi doing the n8n academy quickstart course - stuck at the section on “Generating reports: Retrieving order data” - the workflow works fine but am unable to generate reports as the region and subregion sections remain null. This means somehow despite following the steps as instructed am unable to retrieve the region and subregion fields for this part of the course as returns ‘null’ result which has knock on effect for remainder of the course so cant proceed. sSe set up here: Any advice? Thanks
@rodneylloyd
You need to make sure customerID is coming from Input 2, not Input 1
Your can drag it into the field
