N8n account creation problem
I’m trying to get the Github backup workflow to execute but keep coming up against the error - Problem in node ‘n8n‘ - The resource you are requesting could not be found
Now i believe I got the API correct from Settings but I have no idea whether the base url is correct.
Is something I’ve missed here? I’ve poked around and see reference to the base url including a port and other subdirectories that include /api/ and even the n8n version number which is weird, given the version number changes so often.
Can someone point me in the right direction please. I’m running this in a Docker container via a Cloudflare tunnel.
Does my n8n instance have this base url information displayed somewhere?
Hi @aussiemartin
add “/api/v1” to the end of your baseurl :slight_smile:
ahh ha, thanks so much for this. worked like a dream.
would be good if the docs explained this and/or the credential node gave some clue too.
thanks again.
I agree, but there is a hint to it. Before you fill in your url it shows what it should look like :slight_smile:
