“name”: “a 6”,
“nodes”: [
“parameters”: {
“formTitle”: “Submit URL form”,
“formFields”: {
“values”: [
“fieldLabel”: “URL”
“options”: {}
“type”: “n8n-nodes-base.formTrigger”,
“typeVersion”: 2.2,
“position”: [
-640,
0
“id”: “b537d4fb-0633-407f-9db5-8ff619959e6a”,
“name”: “On form submission”,
“webhookId”: “a79a0be1-f913-444a-b576-ee7937cb909a”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “56fe0e33-deb3-483e-92a7-30a2f2ecc78e”,
“name”: “URL_list”,
“value”: “={{ $json.URL.split(‘,’) }}”,
“type”: “array”
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
-380,
0
“id”: “e9b34931-67c9-4877-b92b-7046aadf63cd”,
“name”: “Edit Fields”
“parameters”: {
“fieldToSplitOut”: “URL_list”,
“options”: {}
“type”: “n8n-nodes-base.splitOut”,
“typeVersion”: 1,
“position”: [
-160,
0
“id”: “99aa4662-2edc-494b-a8b3-2ffb641da4d9”,
“name”: “Split Out”
“parameters”: {
“options”: {
“reset”: false
“type”: “n8n-nodes-base.splitInBatches”,
“typeVersion”: 3,
“position”: [
40,
0
“id”: “7d982dc2-c308-4d1d-925a-146405da29d7”,
“name”: “Loop Over Items”
“parameters”: {
“url”: “https://api.peopledatalabs.com/v5/company/search”,
“genericAuthType”: “httpHeaderAuth”,
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name”: “size”,
“value”: “1”
“name”: “sql”,
“value”: “={{ "SELECT * FROM company WHERE website=‘" + $json.URL_list + "’"}}”
“options”: {}
“typeVersion”: 4.2,
“position”: [
220,
160
“id”: “70f768bc-eccf-41f7-9c9d-0ea789de518f”,
“name”: “HTTP Request”,
“credentials”: {
“httpHeaderAuth”: {
“id”: “7WnvshCamNrQOwYs”,
“name”: “Header Auth account”
“parameters”: {
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: “”,
“typeValidation”: “loose”,
“version”: 2
“conditions”: [
“id”: “afe4c65d-d28d-49d8-9406-4201efc1661e”,
“leftValue”: “={{ $json.status }}”,
“rightValue”: 200,
“operator”: {
“type”: “number”,
“operation”: “notEquals”
“combinator”: “and”
“looseTypeValidation”: true,
“options”: {}
“type”: “n8n-nodes-base.if”,
“typeVersion”: 2.2,
“position”: [
440,
160
“id”: “a3c26d93-15d5-4c7c-b4b3-c45fdd03fd94”,
“name”: “If”
“parameters”: {
“errorMessage”: “Error on PDL enrichment”
“type”: “n8n-nodes-base.stopAndError”,
“typeVersion”: 1,
“position”: [
720,
0
“id”: “80f2766a-eea0-457c-984c-14c4cddc0bb2”,
“name”: “Stop and Error”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “02e35ee1-496b-45b8-82d3-bddb63fb3cdf”,
“name”: “name”,
“value”: “{{ $json.data[0].name }}”,
“type”: “string”
“id”: “eaaee7b9-eb36-4054-bed8-43b5bd0c7273”,
“name”: “employees”,
“value”: “={{ $json.data[0].employee_count }}”,
“type”: “number”
“id”: “4ce756b9-5100-403c-8745-d691ab86e1b2”,
“name”: “country”,
“value”: “{{ $json.data[0].location.contient}}”,
“type”: “string”
“includeOtherFields”: true,
“options”: {}
“typeVersion”: 3.4,
“position”: [
360,
-120
“id”: “8e86f3ca-af5f-4347-8066-0f587031b8ef”,
“name”: “Edit Fields1”
“pinData”: {},
“connections”: {
“On form submission”: {
“main”: [
“node”: “Edit Fields”,
“type”: “main”,
“index”: 0
“Edit Fields”: {
“main”: [
“node”: “Split Out”,
“type”: “main”,
“index”: 0
“Split Out”: {
“main”: [
“node”: “Loop Over Items”,
“type”: “main”,
“index”: 0
“Loop Over Items”: {
“main”: [
“node”: “Edit Fields1”,
“type”: “main”,
“index”: 0
“node”: “HTTP Request”,
“type”: “main”,
“index”: 0
“HTTP Request”: {
“main”: [
“node”: “If”,
“type”: “main”,
“index”: 0
“If”: {
“main”: [
“node”: “Stop and Error”,
“type”: “main”,
“index”: 0
“type”: “main”,
“index”: 0
“active”: false,
“settings”: {
“executionOrder”: “v1”
“versionId”: “acce04e0-85e0-40aa-a66f-4cdae3265ae5”,
“meta”: {
“instanceId”: “d69f5cdce43c830c922c3f27c9cbb4685ba007b56e876fc4150da4afe349b9ab”
“id”: “FD8IbquYAnd1RiqT”,
“tags”:
