Can i setup the max time user can stay logged in?
none
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
- **n8n version:**0.88.0
- **Database you’re using (default: SQLite):**MariaDB 10.4
- **Running n8n with the execution process [own(default), main]:**own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: npm
