I recently completed the n8n Certification Course Level 1, but I have not yet received my test results. Althought i’ve attempted the course multiple times. Could you please check the status for me?
Unique ID: 7ebb7930625b8e2eb8279bd47713aeb1
The progress screen consistently shows an “X” for both “Quiz Score Theory” and “Quiz Score Workflow,” even after I successfully submit my answers. This happens regardless of the different responses I’ve tried.
I’ve created the workflow and with the help of it attempt the quiz, but still didn’t receive the “Test Result email”
Make sure you use same personal email id which means the email id when you sign up the course, where you recieve the unique id should be same as the email id which you enter when you take the test
I also faced the same issue, I completed the test but it shows an “X” for both “Quiz Score Theory” and “Quiz Score Workflow,”. My Unique ID: 9e4fa3cf86d0764530d956d9aeb82c7b. Not sure if there is a system issue or if we need to do something else to complete the course. Can someone please help?
My Progress shows the Same, Unfortunately couldn’t took the Screenshot, when i get the progress verfication email. otherwise. i would post that as well.
