N8n chat hub scrolling issue with the UI
n8n hosted user on version 2.9.1, when I am using the Chat HUB with a workflow agent, each time the agent is using a tool the conversation scroll up, making it impossible to follow what is going on. It is a very annoying UI issue.
Hi @Romain_Dechamps
this is very likely either:
  • A front‑end bug in the current Chat Hub implementation, or
  • An unintended interaction with how tool calls are rendered in the transcript.
the best next steps are: Open a bug report here in the community forum with [Your plan and version,A short screen recording / GIF of the scroll behavior,A minimal example workflow agent that reproduces it]
Or, if you’re on a paid Cloud plan, contact n8n support directly so they can log it as a product bug and track it against upcoming releases.
Hi @Romain_Dechamps Welcome to the community!
That is indeed is a bit of pain when working with Chat, i mostly use that for basic tasks so i switched on to using the Chat node to test workflows although the chat hub is pretty much nice of its own but chat node in the editor UI seems more handy!
