N8n Community light mode/color palette feedback
Hi Team!
I would like to use the n8n Community/forum’s light mode, mainly as I find it easier to read and “softer”. Also, given the fact that the space I work in has large windows, sunshine often makes dark mode (much) harder to use.
However, it feels like the “implementation” of light mode is kind of incomplete. See the screenshot below this post for (at least) 3 areas that are “stuck in dark mode”:
  1. Thread header with fading text: looks really cool in dark mode, but seems like it hasn’t been adapted to fade to another color in light mode.
  2. Code is hard to read; looks like the syntax highlights work but that the default text color is still dark, which ends up on a dark background.
  3. Various other areas are impacted as well.
Obviously, this is not a priority as everything works functionally, and we can still fall back to dark mode. Moreover, I think we all know how busy these times are. Nevertheless, I thought I’d put this out there in case someone sees a possibility to improve this.
Cheers!
@TimothyVermeirenBtry Hi,
You can also vote, I did…
Hello @Haian_Abou-Karam! Thanks for responding. Anywhere in particular we can vote for this?
Hello, vote button should be “enabled” for you, if it is, so you can…
