Hi everyone
Since the update I receive the Connection lost error in the editor. n8n is paired with traefik as reverse proxy. When n8n is set to use sse, the Docker logs show a invalid origin error. If I use the option websocket, n8n can not connect to the websocket.
##The stack configuration
services:
traefik:
image: “traefik”
restart: always
command:
- --api.insecure=true
- --providers.docker
- --providers.file.directory=/etc/traefik/dynamic
- --entryPoints.web.address=:80
- --entryPoints.websecure.address=:443
ports:
- “80:80”
- “443:443”
labels:
- “traefik.enable=true”
- “traefik.http.routers.traefik_https.rule=Host(traefik.${DOMAIN_NAME}
- “traefik.http.routers.traefik_https.entrypoints=websecure”
- “traefik.http.routers.app.tls=false”
- “traefik.http.routers.traefik_https.tls=true”
- “traefik.http.routers.traefik_https.service=api@internal”
volumes:
- ${DATA_FOLDER}/certs/certs:/letsencrypt
- /var/run/docker.sock:/var/run/docker.sock:ro
- /traefik/dynamic_conf.yml:/etc/traefik/dynamic/dynamic_conf.yml:ro
n8n:
image: n8nio/n8n
restart: always
ports:
- “127.0.0.1:5678:5678”
labels:
- traefik.enable=true
- traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`) || Host(`${SUBDOMAIN3}.${DOMAIN_NAME3}`)
- traefik.http.routers.n8n.tls=true
- traefik.http.routers.n8n.entrypoints=web,websecure
- traefik.http.middlewares.n8n.headers.SSLRedirect=true
- traefik.http.middlewares.n8n.headers.STSSeconds=315360000
- traefik.http.middlewares.n8n.headers.browserXSSFilter=true
- traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
- traefik.http.middlewares.n8n.headers.forceSTSHeader=true
- traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
- traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
- traefik.http.middlewares.n8n.headers.STSPreload=true
- traefik.http.routers.n8n.middlewares=n8n@docker
- traefik.http.middlewares.sslheader.headers.customrequestheaders.X-Forwarded-Proto = https
- traefik.wss.protocol=https
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_DIAGNOSTICS_ENABLED=false
- N8N_PUSH_BACKEND=sse
- EXECUTIONS_DATA_PRUNE=true
- EXECUTIONS_DATA_MAX_AGE=12
- EXECUTIONS_TIMEOUT_MAX=7200
- N8N_BLOCK_FILE_ACCESS_TO_N8N_FILES=false
- N8N_SECURE_COOKIE=false
- N8N_RUNNERS_ENABLED=true
- N8N_PROXY_HOPS=1
volumes:
- /root/.n8n:/home/node/.n8n
##Additional information
A certificate is proxied using a functionality of a firewall.
- **n8n version: 1.90.2
- **Database (default: SQLite): SQLite
- **n8n EXECUTIONS_PROCESS setting (default: own, main): own,main
- **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
- **Operating system: Debian 11
Thanks in advance for your help.
