My unique ID is 7c79256237b9b764cf65a465d56c6b65. I have retaken the quiz on Sat 22:21 IST( Feb 14th 2026. I have not received my quiz results through the mail. Checked the website using the unique ID I am still getting old results. Please help.
Hello @Rangarajan_Hariharan.
Sometimes it takes a few minutes for the results to arrive.
Are you sure you used the correct User ID from your profile as well ?
Bro three days over. Not yet received.
Yes used correct unique id.
Hi @Rangarajan_Hariharan Welcome to the community!
I have verified that you have not passed the level 1 quiz both in theory and in practical workflow, below is your report:
Please consider going through the below quiz again:
Hope this helps, kindly mark this as a solution.
Result you checked old one which i wrote on Friday. I wrote once again on Sat. I have not received result yet.
The one i gave is the final result @Rangarajan_Hariharan, as your progress between n8n courses are tracked using unique_id so you have to retake the test.
According to our systems, there is only 1 attempt currently registered with this id.
For retaking test can i do with same unique id or different id.
Use the same ID and email address for everything.
Bro once again i have retaken quiz and completed around 22:04 PM IST. Still not received results. I dont know what to do now. Please do the needful. I have taken screenshot of the quiz completion.
Hi @Rangarajan_Hariharan You have not scored enough to pass the level 1 test although the email should have been sent to you but currently here is your result, retake the quiz to pass:
Please, bro i wrote three times. I think they are cheating by not updating the results. It is a mere waste of time to retake the quiz.
Our system only has a single attempt registered to this ID.
How go create new unique id and retake quiz.
You should use the same ID and retake the quiz with that same 7c79256237b9b764cf65a465d56c6b65 ID. This ID is how we track your total progress.
Bro, I wrote 3 times. Got fed up. I am planning not to retake the quiz.
I understand your frustration but you have not scored more than 80% in any of the tests:
And consider using your unique_id and community user ID. I guess you are not using correct unique_id or email cause as you are claiming that you have given tests but it shows the same results as before, consider using the same unique_id which is 7c79256237b9b764cf65a465d56c6b65
Bro, I have cleared my level 1. Thank you for replying to my message.
@Rangarajan_Hariharan Glad it worked, kindly mark that as a solution.
