Hello, Stanley
My past relevant work : https://planner5d.com/
I contributed to a Planner5D-style platform where users can generate both 2D and 3D building layouts through intuitive interfaces and dynamic parameter inputs. This experience directly aligns with your need for a rule-driven, export-capable building generator.
I’m a seasoned Full-Stack and 3D Web Developer with extensive experience in building parametric modeling systems and visual configuration tools. I specialize in developing tools like what you’ve described—where logic, data, and user input drive both 2D layout creation and real-time 3D visualization.
Project Experience Similar to Yours:
I built a dynamic floor plan configurator similar to Planner5D that allowed users to generate structures in real-time with editable parameters (walls, roof styles, materials, etc.). The system was fully exportable to CAD formats like DXF and included PDF generation for reports and layout summaries. This tool used Three.js for rendering, Python scripts for geometry processing, and supported custom rule-based validations to guide design accuracy.
How I Will Approach Your Project:
2D/3D Engine: Using Three.js and Canvas2D for frontend generation; optionally, Babylon.js or Unity if real-time performance needs demand it.
Rule-Based Logic: I’ll implement dynamic input forms linked to a constraint engine that enforces rules on geometry and building specs.
Export: Use libraries like dxf-writer, jsPDF, or server-side conversion for robust DXF/PDF support.
Scalability: I architect with modular code (TypeScript or modern JS) so updates are seamless—ready for future integration or product scaling.
Preferred Stack:
Frontend: React.js, Three.js, Canvas2D
Backend: Node.js or Python (Flask/FastAPI)
Exporting Tools: jsPDF, dxf-writer, Puppeteer
Optional: Unity or Three.js for ultra-high fidelity rendering if needed
This project is well within my wheelhouse, and I’m confident I can build a solution that is robust, scalable, and visually compelling. I’d be happy to discuss a quick roadmap to help you visualize what the MVP would look like and how long it would take.
Let’s turn your data and rules into a powerful modeling tool.
Looking forward to connecting,
