N8N download click does not respond in any node
Clicking Download in any node (ex: Write Binary to File) does not respond. No error either.
  • n8n version:0.227.0
  • Database: Postgres
  • n8n EXECUTIONS_PROCESS setting: default
  • Running n8n via (Docker, npm, n8n cloud, desktop app): Docker K8
  • Operating system:Linux
Hi @Gowthaman_Prabhu :wave:
You’re on quite an older version of n8n - can you try upgrading, and see if this issue persists?
If it does after the upgrade, can you share what version number you’re on (hopefully latest!) and a workflow where this is happening for you? Would you also be able to share some logs? :pray:
There are no logs produced when running locally either.
Is there an issue with this verison of n8n: 0.227.0 ?
It is simply an old version. So updating would be the best way to solve this issue.
The n8n team cannot support all versions that have come out seperately.
Of course if you update and the issue still persists they can have a look at what is going wrong, but it is highly possible it is already fixed.
