When I use dynamic fields with values and try to send them as fixed, it works perfectly. However, when I try expressions like Airtable expressions, it doesn’t send any data with dynamic fields. I have tried many solutions, and even AI agents like Claude or GPT have told me, “No, N8N does not natively support expressions with dynamic fields.”
I cannot use static fields because I get fields by API request, and sometimes there are 3 fields, and sometimes there are 10, etc. Is there any solution, or should I just give up on that?
Thanks for posting here and welcome to the community!
Pretty sure there is a solution Could you share your workflow though, ideally with some pinned dummy data? Then please also provide some screenshots of what you need to achieve?
Thanks for helping to understand your issue better!
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
Thank you for your response. My issue regarding the custom node building is not about workflows, but I found a solution for it using pre-functions, and it works like a charm.
