N8n error messages are hard to debug — is anyone building better error explanations?
Hey community :waving_hand:
I’ve been building with n8n for a while now and one thing that consistently slows me down is the error messages. They’re technically correct, but they’re not always actionable.
For example, I recently got this:
Invalid node execution. Check your data structure.
No indication of which node failed. No hint of what “data structure” issue it’s referring to. I eventually tracked it down to a missing field in an HTTP Request node — but it took 30+ minutes of Googling, reading
GitHub issues, and asking in Discord.
This happens a lot. The errors don’t typically tell you:
  • Which node broke
  • Why it broke in plain language
  • What to change to fix it
I’ve been thinking about building a small tool (likely a Chrome extension) that sits alongside the n8n editor and explains errors in plain English when they appear — something like “This error means your HTTP
Request node is missing the Authorization header. Here’s how to fix it.”
Questions for the community:
  1. Is this a pain point you experience too?
  2. Are there existing tools or workarounds you use for this?
  3. Would something like this be useful to you?
Genuinely curious before investing time to build it. Happy to share progress here if there’s interest.
If you’re only relying on n8n’s built-in error messages, I can definitely see the frustration. They may be technically correct, but they don’t always tell you what to do next.
A few tutorials from my recent n8n QA/testing series here in the community may help if you want to build your own stronger error-handling system:
Article 7: Using execution logs to find the failed node, inspect input/output data, and trace the real cause.
Article 4: validating data early so missing fields get caught before nodes like HTTP Request fail.
Article 6: Setting up an error workflow so failures get logged and alerted in a more useful way.
Your Chrome extension idea could be valuable, especially if it combines the error message with execution-log context instead of only explaining the generic error text.
