I’m using a custom Dockerfile to install some extra packages.
FROM n8nio/n8n
USER root
RUN npm install -g hyperformula
RUN npm install -g lodash
RUN npm install -g moment
RUN npm install -g moment-timezone
RUN npm install -g moment-duration-format
RUN npm install -g axios
USER node
And using this Dockerfile on my Docker Compose file, enabling the required package using the environment variables.
n8n:
# image: docker.n8n.io/n8nio/n8n
build:
context: .
dockerfile: Dockerfile
restart: always
ports:
- "127.0.0.1:5678:5678"
environment:
- N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- NODE_FUNCTION_ALLOW_BUILTIN="*"
- NODE_FUNCTION_ALLOW_EXTERNAL="hyperformula,moment,lodash"
- N8N_REINSTALL_MISSING_PACKAGES=true
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
volumes:
- n8n_data:/home/node/.n8n
- ./local-files:/files
Then while trying to run the Code I’m getting:
"errorMessage": "Cannot find module 'hyperformula' [line 1]",
"errorDescription": "VMError",
"errorDetails": {},
"n8nDetails": {
"nodeName": "Code",
"nodeType": "n8n-nodes-base.code",
"nodeVersion": 2,
"n8nVersion": "1.91.3 (Self Hosted)",
"binaryDataMode": "default",
"stackTrace": [
"VMError: Cannot find module 'hyperformula'",
" at LegacyResolver.resolveFull (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver.js:126:9)",
" at LegacyResolver.resolveFull (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver.js:316:16)",
" at LegacyResolver.resolveFull (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver-compat.js:147:17)",
" at LegacyResolver.resolve (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/resolver.js:121:15)",
" at resolve (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/nodevm.js:317:21)",
" at VM2 Wrapper.apply (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/bridge.js:490:11)",
" at requireImpl (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/setup-node-sandbox.js:90:19)",
" at require (/usr/local/lib/node_modules/n8n/node_modules/@n8n/vm2/lib/setup-node-sandbox.js:171:10)",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Code:1:121",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Code:39:2"
The code:
