Hey Team,
I want to setup local env in my macOS; i’m getting build error. need help on local environment setup
transforming (4547) …/…/node_modules/.pnpm/[email protected]/node_modules/rec ELIFECYCLE Command failed with exit code 1.
n8n-editor-ui:build: ERROR: command finished with error: command (/workspaces/packages/editor-ui) /usr/local/bin/pnpm run build exited (1)
n8n-editor-ui#build: command (/workspaces/packages/editor-ui) /usr/local/bin/pnpm run build exited (1)
Tasks: 16 successful, 18 total
Cached: 16 cached, 18 total
Time: 41m22.809s
Failed: n8n-editor-ui#build
ERROR run failed: command exited (1)
- **n8n version:1.79
- **Database (default: SQLite):SQLite
- **n8n EXECUTIONS_PROCESS setting (default: own, main):default
- **Running n8n via (Docker, npm, n8n cloud, desktop app): github code
- **Operating system:macs
