N8N goes offline
Hi everyone,
actually I got a problem
after I run the workflow it goes through some nodes and then it blocks at one node and n8n goes offline
what could be the solution of this issue
thank you
Hey @salaheddine_bannaq, while you wait for a response, here are some things that might help:
Suggested resources
Docs:
Forum:
@kjooleng, @JonathanTAU, @Wouter_Nigrini - you’ve helped with similar issues before, can you take a look?
Hi Salaheddine,
Zara here from m8m support. Thanks for sharing the screenshot. I’m sorry the workflow stops partway through and takes n8n offline.
To help me look into this on the n8n side, could you share a few details?
  1. Which node is the workflow stuck on when n8n goes offline?
  2. The workflow JSON. Export the workflow and attach the json to the email.
  3. Are you on n8n Cloud or self hosted, and which n8n version are you running?
Please send the JSON and those details to help@n8n.io and feel free to include a link to this thread in your email so we can match it up quickly.
Once we have it, we will guide you further.
Best Regards,
Zara
That usually means the instance is running out of memory on that node, so it crashes and restarts. Check the container or server logs for an out-of-memory kill right when it drops. If that node handles a big payload or lots of items, process them in smaller batches or split the work into a sub-workflow. Which node is it, and are you self-hosting or on cloud?
Hey Zara,
Thank you for reaching out.
I already worked with this workflow and everything went alright, but somehow I felt like n8n isn’t strong enough to execute the workflow ( maybe this is because of my laptop’s capacity.
The nodes are Get rows in sheet and get rows
Hey, it’s probably the laptop’s memory rather than n8n itself. Get rows on a big sheet loads everything at once, so try limiting the rows or running it in smaller batches with Split In Batches. Are you running it locally or in Docker?
When n8n suddenly drops offline mid-execution, the host container is almost certainly getting killed by out-of-memory limits.
Splitting large item batches with a Loop Over Items node or bumping the Docker memory limit usually prevents the Node process from crashing.
Since it stops at Get rows in sheet, I’d guess the sheet is large and everything loads into memory at once on a laptop. Try setting a Limit on that node, or add a filter so it only pulls the rows you need, and run the downstream nodes through Loop Over Items with a batch size of 50-100. If it still drops, check how much RAM Docker or Node is allowed to use. That alone often stops the crash.
Hi @salaheddine_bannaq, one addition to the suggestions above: a Loop Over Items node after Google Sheets can reduce the batch size for downstream nodes, but the Sheets node will already have fetched its rows by then.
Could you test the workflow against a smaller sheet or range and see whether it still goes offline? Memory is one possible cause, but the logs around the crash should help confirm what happened.
