I have seen this issue while I was trying to configure queue mode. Would like to know if this is fixed
in 1.15.2 version of n8n.
In addition to this, I have another issue. when I use console.log(“print something”) in the code node in my workflow, I see that its going to the browser console log. But nothing in the container logs. (I have n8n in a kubernetes cluster) and I am trying to see something debug message in the logs of the container, when
I run this command:
kubectl logs -f n8n-worker-my-5f6786dffc-6x485 -n my-n8n-ns
Log looks like this: But console.log(“print something”) doesn’t get here:
appreciate any direction. the workflow is very simple, just a code node with console.log
2023-11-19T16:38:38.583Z | info | Start job: 15 (Workflow ID: FtyXINka7eIX0fSG | Execution: 561) "{ file: 'worker.js', function: 'runJob' }"
2023-11-19T16:38:38.594Z | verbose | Workflow execution started "{\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.verbose'\n}"
2023-11-19T16:38:38.596Z | debug | Start processing node "Schedule Trigger" "{\n node: 'Schedule Trigger',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.597Z | debug | Running node "Schedule Trigger" started "{\n node: 'Schedule Trigger',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.597Z | debug | Running node "Schedule Trigger" finished successfully "{\n node: 'Schedule Trigger',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.598Z | debug | Start processing node "Code" "{\n node: 'Code',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.599Z | debug | Running node "Code" started "{\n node: 'Code',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.606Z | debug | Running node "Code" finished successfully "{\n node: 'Code',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.debug'\n}"
2023-11-19T16:38:38.608Z | verbose | Workflow execution finished successfully "{\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'LoggerProxy.js',\n function: 'exports.verbose'\n}"
2023-11-19T16:38:38.608Z | debug | Executing hook (hookFunctionsSaveWorker) "{\n executionId: '561',\n workflowId: 'FtyXINka7eIX0fSG',\n file: 'WorkflowExecuteAdditionalData.js',\n function: 'workflowExecuteAfter'\n}"
2023-11-19T16:38:38.609Z | debug | Save execution data to database for execution ID 561 "{\n executionId: '561',\n workflowId: 'FtyXINka7eIX0fSG',\n finished: true,\n stoppedAt: 2023-11-19T16:38:38.608Z,\n file: 'sharedHookFunctions.js',\n function: 'updateExistingExecution'\n}"
2023-11-19T16:43:08.079Z | info | Stopping n8n... "{ file: 'worker.js', function: 'stopProcess' }"
