N8n in docker and ssl issues
When mounting my Certbot let’s encrypt certificates to the docker container it can read the fullchain.pem file but not the privatekey.pem file (due to the docker container not having root access to read the files). I have tried to use a reverse proxy on the host but the docs are quite vague.
permission denied to read privatekey on start
  • n8n version: 2.9.4
  • Operating system: Debian 13
Hi @Bejing_Corn Welcome!
Have you tried using a reverse proxy like Nginx or Traefik to handle SSL termination rather than just passing certificates to the container, what i mean is that Ngnix running on Host must have root access so that it can read certbot private key , also n8n only receives plain HTTP from localHost.
Your config should be like this i think:
server {
    listen 80;
    server_name your-domain.com;
    return 301 https://$host$request_uri;
server {
    listen 443 ssl;
    ssl_certificate /etc/letsencrypt/live/your-domain.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/your-domain.com/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    location / {
        proxy_http_version 1.1;
        proxy_set_header Connection "upgrade";
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_buffering off;
        proxy_read_timeout 3600;
        proxy_send_timeout 3600;
And then ofc you have to set env variables like this:
environment:
  - N8N_HOST=your-domain.com
  - N8N_PORT=5678
  - N8N_PROTOCOL=https
  - WEBHOOK_URL=https://your-domain.com/
  - N8N_PROXY_HOPS=1
  - NODE_ENV=production
And that should work. Hope this helps.
Yes I have tried using a reverse proxy (nginx) but I ran into some issues with the n8n client communicating with the server. It could not initiate a web socket connection running though the proxy and I just gave up on that. Il’l try again.
EDIT: Its also having issues communicating with the rest api
hi @Bejing_Corn - please share your docker compose file - likely you’ll need to map the ports or validate docker network is open to both nginx and n8n containers.
I just fixed it. I set n8n to connect to the proxy though https rather than http :person_facepalming:.
Here is my config anyway:
Docker:
services:
  n8n:
    image: docker.n8n.io/n8nio/n8n
    container_name: n8n
    ports:
      - "127.0.0.1:5678:5678"
    restart: unless-stopped
    environment:
      - GENERIC_TIMEZONE=Pacific/Auckland
      - TZ=Your/Timezone
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - N8N_PROTOCOL=http
      - N8N_HOST=example.com
      - N8N_PORT=5678
      - WEBHOOK_URL=https://n8n.example.com/
      - N8N_PROXY_HOPS=1
    volumes:
      - n8n_data:/home/node/.n8n
volumes:
  n8n_data:
Nginx:
server {
    listen 80;
    server_name example.com;
server {
    listen 443 ssl;
    ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
    location / {
I also had to add:
large_client_header_buffers 8 32k;
into nginx.conf to allow google oauth with lots of scopes.
Maybe n8n could update the docs with a how-to guide for this stuff.
