N8N issue due to webhook migration
I can’t login into my N8N UI stack, i tried to connect the console and resert my password but i have an error message linked to a webhook migration.
I have several workflow using webhook and this errors happened already in the past i had to rebuild from zero. I’m happy to start over from zero but i need at least to backup some workflow this time to not loose everything.
Migration “AddWebhookId1611144599516” failed, error: column “webhookId” of relation “webhook_entity” already exists
  • n8n version: LATEST
  • Database (default: SQLite): SQLITE
  • Running n8n via (Docker, npm, n8n cloud, desktop app): DOCKER
  • Operating system: LINUX
what you get if you export by command line?
can you try to disable workflow by cli before export?
For now when the container restart in loop due to this error :
Initializing n8n process
n8n ready on 0.0.0.0, port 5678
Migrations in progress, please do NOT stop the process.
Starting migration AddWebhookId1611144599516
Migration "AddWebhookId1611144599516" failed, error: column "webhookId" of relation "webhook_entity" already exists
There was an error running database migrations
Permissions 0644 for n8n settings file /home/node/.n8n/config are too wide. This is ignored for now, but in the future n8n will attempt to change the permissions automatically. To automatically enforce correct permissions now set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true (recommended), or turn this check off set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false.
User settings loaded from: /home/node/.n8n/config
Last session crashed
I can’t get access to container anymore
