I am currently facing a challenge with n8n and need help from the community. Here’s the context:
I am trying to iterate through all leads stored in a Supabase table and execute a query for each lead to match them with emails stored in another table. Initially, I attempted to achieve this using the Loop node, which seemed to work, but I couldn’t figure out how to make it iterate through the entire table. Eventually, I designed the workflow described below, which works fine except for a strange issue with how items are handled in one of the branches.
Here’s what happens:
- In the ‘Get leads’ node, I set a limit of 3. This returns the following leads:
- Lead 1: { id: 3320 }
- Lead 2: { id: 7444 }
- Lead 3: { id: 9755 }
- In the subsequent ‘Code’ node, I prepare queries for each lead, resulting in three items:
- Item 1: { id: 3320, query: “Has one matching email in database, id: 33881” }
- Item 2: { id: 7444, query: “No matching emails in database” }
- Item 3: { id: 9755, query: “Has one matching email in database, id: 34528” }
- Now, we step into the ‘Set lead ID for the matching emails’ node. I expect this node to run an update query for each item individually, so at the end, I should have email 33881 connected to lead 3320 and email 34528 connected to lead 9755.
However, this is not what happens. Instead, the output looks like this:
"id": 33881,
"lead_id": 3320
"id": 33881,
"lead_id": 7444
"id": 33881,
"lead_id": 9755
And when I check the database, email 33881 is connected to lead 9755.
My understanding is that each node in n8n should process items individually within its own context. I was expecting each item to be handled independently, but it seems like the same email ID (33881) is being used across all leads.
Is this a bug in n8n? Or am I misunderstanding how the item processing works in n8n workflows?
I would really appreciate any insights or guidance on this issue. Thanks in advance!
The workflow:
- n8n version: 1.73.1
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
- Operating system: macOS
