While merging from fields of airtable and HTTP request, it gives an error as “Field ‘customerCountry’ is not present in any of items in ‘Input 1’”, but the customerCountry field do exist in Input 1 table. How to solve this issue?
Hey @Kavya,
Welcome to the community
Looking at the screenshot it looks like the value would be fields.customerCountry
, It is something I have in my notes for a course update so it should work for you. Let me know how you get on.
Thank you for the reply. The error I have mentioned is solved but, it gives another error as "Field ‘name.common’ is not present in any of items in ‘Input 2’ ". I tried by renaming Input 2 field as “fields.name.common” as well, but failed.
Hey @Kavya,
name.common
looks to be correct looking at the output from the API, When ran the workflow did you run the entire thing or just the one node? The workflow below is what I have just used to test.
Thank you so much! It’s working now.
