N8n loading issue stops responding and becomes stuck
I’m facing an issue with n8n. My n8n instance is hosted on Hostinger. It runs fine for a few minutes after I restart the server, but then it stops responding and becomes stuck. I’m unable to continue my work because of this. Has anyone experienced this issue before? If you have any idea what might be causing it, please help
@Channel2_TwentySeven are you using Docker ?
Can you paste some logs?
@Channel2_TwentySeven Share some screenshot or Paste logs for understanding.
On hostinger, can you use docker?
