Hello there!
Just started out with n8n, and one major bummer I came across is the Nextcloud integration. I use Nextcloud in my daily workflow, and as far as I see there is no way currently to use n8n to edit Excel like files in my Nextcloud instance the same way I can with Google Sheets.
Google sheets allows you to really use the sheet as a database for the workflow, and I really want to move that over to my own cloud.
Does anyone know of a workaround to getting the same functionality with Nextcloud? Or do I need to start working on my own n8n node ![]()
