N8n not connecting to elevenLabs agent
I’ve built an agent on Eleven labs that needs to be connected to an n8n Workflow. But for some reason the webhook isn’t finding the eleven labs agent.
I’ve double checked that the webhook url matches the one found in the elevenlabs tool, which it does. I’ve also tested the webhook request through postman, and it was successful.
Is there anything I’m missing here? {
“nodes”: [
“parameters”: {
“promptType”: “define”,
“text”: "Customer that is requesting changes: ",
“options”: {
“systemMessage”: “=You are a helpful booking assistant to a Catering Company with over 30 years of Experience in the Industry. Your job is to send an email to customers\n\nStyle Guidelines:\n\n”
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 3.1,
“position”: [
880,
0
“id”: “8927c944-1c5c-4275-a0f5-90c11eff795a”,
“name”: “AI Agent”
“parameters”: {
“modelName”: “models/gemini-3.1-flash-lite”,
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.lmChatGoogleGemini”,
“typeVersion”: 1.1,
“position”: [
576,
272
“id”: “28a25440-0ec4-4516-9a5f-7557a17f1b73”,
“name”: “Google Gemini Chat Model”,
“credentials”: {
“googlePalmApi”: {
“id”: “r5K1AFY1c2dmiqsE”,
“name”: “Google Gemini(PaLM) Api account”
“parameters”: {
“httpMethod”: “POST”,
“path”: “elevenlabs-agent”,
“responseMode”: “responseNode”,
“options”: {}
“type”: “n8n-nodes-base.webhook”,
“typeVersion”: 2.1,
“position”: [
0,
0
“id”: “c41ecac9-fa6a-43bf-9f56-20f3aa180506”,
“name”: “Webhook”,
“webhookId”: “5cb182b6-458e-47ef-b135-1f13c4bba464”,
“onError”: “continueRegularOutput”
“parameters”: {
“sendTo”: “barrtimm@gmail.com”,
“subject”: “Updated booking”,
“options”: {}
“type”: “n8n-nodes-base.gmail”,
“typeVersion”: 2.2,
“position”: [
1216,
0
“id”: “61b1ea10-4721-42f7-b75a-037e78ea3dbc”,
“name”: “Send a message”,
“webhookId”: “44038102-5fdb-43b4-a483-f9e17836d2f7”,
“credentials”: {
“gmailOAuth2”: {
“id”: “49vocCpyDoaHrQbO”,
“name”: “Gmail OAuth2 API”
“parameters”: {},
“type”: “@n8n/n8n-nodes-langchain.memoryBufferWindow”,
“typeVersion”: 1.4,
“position”: [
992,
272
“id”: “d968a2be-b208-47d8-a1f3-899caf75b969”,
“name”: “Simple Memory”
“parameters”: {
“assignments”: {
“assignments”:
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
640,
0
“id”: “4c3bf6b3-8e27-479d-92df-5493766e2c37”,
“name”: “Edit Fields”
“parameters”: {
“options”: {}
“type”: “n8n-nodes-base.respondToWebhook”,
“typeVersion”: 1.5,
“position”: [
1424,
0
“id”: “873db63d-a8d7-493e-b57b-b8465b41f427”,
“name”: “Respond to Webhook”
“connections”: {
“AI Agent”: {
“main”: [
“node”: “Send a message”,
“type”: “main”,
“index”: 0
“Google Gemini Chat Model”: {
“ai_languageModel”: [
“node”: “AI Agent”,
“type”: “ai_languageModel”,
“index”: 0
“Webhook”: {
“main”: [
“node”: “Edit Fields”,
“type”: “main”,
“index”: 0
“Send a message”: {
“main”: [
“node”: “Respond to Webhook”,
“type”: “main”,
“index”: 0
“Simple Memory”: {
“ai_memory”: [
“node”: “AI Agent”,
“type”: “ai_memory”,
“index”: 0
“Edit Fields”: {
“main”: [
“node”: “AI Agent”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “845031bfdb8f607d8c7ae907fb5de28c6fb4d0a8d0cd06c1a605d7c42f4018a9”
Hi Tim,
If the webhook works in Postman but not when triggered from the ElevenLabs Agent, you are likely hitting an issue with the request body structure or header validation. ElevenLabs often sends requests with specific content types that n8n’s webhook node might require explicit configuration to handle.
Here are the three things to check to isolate the issue:
  1. Request Body Type: ElevenLabs may send data as application/json or as raw text/form data. In your n8n Webhook node, ensure “Respond with JSON” is enabled, but also check that “Ignore HTTP Header Content-Type” is toggled ON. Sometimes n8n rejects incoming payloads if the content-type header from ElevenLabs doesn’t perfectly match what it expects.
  2. The “Webhook ID” Mismatch: Looking at your provided JSON, your Webhook node is named Webhook and is set to responseNode. Verify that the URL you pasted into ElevenLabs is the Production URL (not the Test URL). If you are using the Test URL, it will not trigger the workflow unless you are actively looking at the editor.
  3. Authentication/Header Echo: Does your ElevenLabs agent require a handshake or a specific header back? If ElevenLabs expects a specific JSON response format (e.g., a specific key like {"status": "ok"}), the Respond to Webhook node must be configured to return that specific object. If the agent sends a request and gets an empty or malformed response, it will “time out” or show as “not found” on their end.
Temporarily change your Webhook node to “Respond Immediately” and connect it to a “Set” node that saves the incoming payload to a Google Sheet or an n8n “Table.” If the data appears in the table after an ElevenLabs trigger, you know the connection is fine, and the issue is specifically with the response the agent is expecting back from you.
Also, check your n8n logs (if self-hosted) for any 400 or 500 errors at the exact timestamp of the failed trigger—that will tell you immediately if it’s a header mismatch or a payload parsing error.
Best, Swapnil swapnilailabs.com
