I’m running latest n8n via docker, I’m trying to write a file to /home/node/.n8n using write file to disk node. It returns not writable error. But it’s ok if I try to write a file in shell:
C:\Users\XT>docker exec -it 05d6a1a76470 /bin/sh
~ $ whoami
node
~ $ ls -a
. .. .ash_history .cache .n8n testoutput.txt
~ $ ls -ld .n8n
drwxrwxrwx 1 node node 4096 Mar 17 09:31 .n8n
~ $ pwd
/home/node
~ $ cd .n8n
~/.n8n $ ls
binaryData database.sqlite n8nEventLog-1.log n8nEventLog.log workflow_export_import
config docker-compose.yml n8nEventLog-2.log ssh
crash.journal git n8nEventLog-3.log testoutput.txt
~/.n8n $ touch test_input.txt
~/.n8n $ ls -l test_input.txt
-rwxr-xr-x 1 node node 0 Mar 17 09:39 test_input.txt
~/.n8n $ echo hello > test_input.txt
I have also tried this :
~/.n8n $ chown -R --verbose node:node /home/node/.n8n
changed ownership of '/home/node/.n8n/binaryData' to 1000:1000
changed ownership of '/home/node/.n8n/config' to 1000:1000
changed ownership of '/home/node/.n8n/crash.journal' to 1000:1000
changed ownership of '/home/node/.n8n/database.sqlite' to 1000:1000
changed ownership of '/home/node/.n8n/docker-compose.yml' to 1000:1000
changed ownership of '/home/node/.n8n/git' to 1000:1000
changed ownership of '/home/node/.n8n/n8nEventLog-1.log' to 1000:1000
changed ownership of '/home/node/.n8n/n8nEventLog-2.log' to 1000:1000
changed ownership of '/home/node/.n8n/n8nEventLog-3.log' to 1000:1000
changed ownership of '/home/node/.n8n/n8nEventLog.log' to 1000:1000
changed ownership of '/home/node/.n8n/ssh' to 1000:1000
changed ownership of '/home/node/.n8n/test_input.txt' to 1000:1000
changed ownership of '/home/node/.n8n/testoutput.txt' to 1000:1000
changed ownership of '/home/node/.n8n/workflow_export_import/My_test.json' to 1000:1000
changed ownership of '/home/node/.n8n/workflow_export_import/My_workflow.json' to 1000:1000
changed ownership of '/home/node/.n8n/workflow_export_import' to 1000:1000
changed ownership of '/home/node/.n8n' to 1000:1000
~/.n8n $ ls -la /home/node
total 28
drwxr-sr-x 1 node node 4096 Mar 17 09:34 .
drwxr-xr-x 1 root root 4096 Feb 14 19:12 ..
-rw------- 1 node node 220 Mar 17 10:03 .ash_history
drwxr-sr-x 3 node node 4096 Mar 17 09:17 .cache
drwxrwxrwx 1 node node 4096 Mar 17 09:47 .n8n
-rw-r--r-- 1 node node 6 Mar 17 09:18 testoutput.txt
