N8n notion connection
Hey everyone, I am trying to setup my connection to notion with n8n. I have in my internal integration key but I keep seeing this in n8n. Any help on this? Thank you.
Hey @Isaiah_Solomon hope all is good. Welcome to the community.
Did you add the integration to the database to give it access?
Under Connections:
Yes I have my connection to n8n setup with it. @jabbson
and if you hover over the red triangle with an exclamation mark, what is the error?
It says parameter database is required
I see, and under integrations on the dev site, you gave your integration all the necessary capabilities?
I gave It all content capabilities yes
In n8n it even says the connection was tested successfully
@jabbson this is what returns
Sorry, @Isaiah_Solomon the only way I can reproduce this behaviour is if I don’t have an active “connection” setup for the integration. Credentials show all good, but no databases are in the dropdown. Check you are actually authorize the integration to access database pages and that you are using the correct integration token.
