n8n not working behind traefik and caddy. When we deploy a standalone docker compose stack behind a traefik firewall routing to caddy and then to a n8n subpath we get an incorrect path from n8n for assets .
Running in a github codespace the same caddy config works perfectly well
Comparing the two systems, in codespace n8n requests assets with the sub path. In deployment the sub path ismissing. I have compared both docker compose files and the n8n entry is identical - image, variables (except content) etc
Failed to load module script: Expected a JavaScript-or-Wasm module script but the server responded with a MIME type of “text/html”. Strict MIME type checking is enforced for module scripts per HTML spec.
- n8n version: 114-3:
- Database (default: SQLite): postgres
- n8n EXECUTIONS_PROCESS setting (default: own, main): queue
- Operating system: Ubuntu 24.10
