Objective: Install uuid
library for Node, so I can generate UUIDs with a
I am running n8n using the n8nio/n8n:latest-debian
container image on an ODROID M1 (arm64) with Ubuntu Server 22.04 LTS. I used the Docker Engine to run the n8n container.
After creating an account and logging in, I tried to create a Command node that runs npm install --global uuid
Unfortunately, I am getting a permissions error, saying that I can’t install the module. Any ideas why this error is happening? I tried switching from the latest
container image to the latest-debian
image, but that didn’t change anything.
Problem in node ‘Execute Command‘
Command failed: npm install --global uuid npm ERR! code EACCES npm ERR! syscall mkdir npm ERR! path /usr/local/lib/node_modules/uuid npm ERR! errno -13 npm ERR! Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/uuid’ npm ERR! [Error: EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/uuid’] { npm ERR! errno: -13, npm ERR! code: ‘EACCES’, npm ERR! syscall: ‘mkdir’, npm ERR! path: ‘/usr/local/lib/node_modules/uuid’ npm ERR! } npm ERR! npm ERR! The operation was rejected by your operating system. npm ERR! It is likely you do not have the permissions to access this file as the current user npm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the npm ERR! permissions of the file and its containing directories, or try running npm ERR! the command again as root/Administrator. npm ERR! A complete log of this run can be found in: npm ERR! /home/node/.npm/_logs/2023-03-16T22_15_46_687Z-debug-0.log
Please share the workflow
N/A
- n8n version: latest
- Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]: default
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
