Hello, I would like to know if the node Postgres PGVector Store integrations | Workflow automation with n8n accepts special filter on the metadata field, currently I’m only able to use it to filter simple equality, example:
price: 500
I would like to use filters like:
price: {“$gte”: 500, “$lte”: 1000}
How to do it?
jabbson
September 5, 2025, 6:22pm
2
From what I see in the code, and from sniffing the traffic, currently the filter is built around eq operator, which means that it will search for the exact value, where for the filter created like so:
it will produce the query:
SELECT *, "embedding" <=> $1 as "_distance"
FROM n8n_vectors
WHERE metadata->>'price' = $3
ORDER BY "_distance" ASC
LIMIT $2;
Feel free to open a FR for other operators, if one doesn’t exist yet.
system
Closed
December 4, 2025, 6:22pm
3
