The n8n deployment in the n8n namespace is failing to start and is stuck in a CrashLoopBackOff state. The issue persists despite multiple restart attempts.
Environment:
Kubernetes Version: Check via kubectl version
Cloud Provider: Azure AKS
n8n Image Version: n8nio/n8n:latest
Database: PostgreSQL (Running as postgres-service.n8n.svc.cluster.local)
Storage: PersistentVolumeClaim n8n-claim0
Deployment Details:
Deployment strategy: Recreate
Pod uses an init container (busybox:1.36) to set permissions on /data
n8n environment variables:
DB_TYPE=postgres
DB_POSTGRESDB_HOST=postgres-service.n8n.svc.cluster.local
DB_POSTGRESDB_PORT=5432
DB_POSTGRESDB_DATABASE=n8n
N8N_PROTOCOL=http
N8N_PORT=5678
N8N_LOG_LEVEL=debug
Error Logs:
kubectl get pods -n n8n shows:
NAME READY STATUS RESTARTS AGE
n8n-7bf5986bbb-2trxp 0/1 CrashLoopBackOff 6 (2m37s ago) 8m55s
postgres-6665f78f5f-2scgl 1/1 Running 1 (4h38m ago) 4h39m
kubectl describe pod n8n-7bf5986bbb-2trxp -n n8n shows:
State: Waiting - Reason: CrashLoopBackOff
Last State: Terminated - Reason: Error - Exit Code: 2
Possible Causes Investigated:
Database connection issues (verified PostgreSQL is running)
Storage mount permissions (init container runs successfully)
n8n misconfiguration (environment variables appear correct)
Steps to Reproduce:
Deploy n8n using Kubernetes with the above configuration.
Monitor pod status via kubectl get pods -n n8n.
Inspect logs using kubectl logs n8n- -n n8n.
Expected Behavior:
The n8n pod should start successfully and be available.
Actual Behavior:
The pod repeatedly crashes with Exit Code 2.
Additional Context:
Any insights or troubleshooting suggestions would be greatly appreciated.
kubectl exec -it postgres-6665f78f5f-2scgl -n n8n -- psql -U admin -d n8n -h postgres-service.n8n.svc.cluster.local
Password for user admin:
psql (11.16 (Debian 11.16-1.pgdg90+1))
Type "help" for help.
n8n=# \dt
Did not find any relations.
n8n=# \dn
List of schemas
Name | Owner
public | admin
(1 row)
n8n=# \l
List of databases
Name | Owner | Encoding | Collate | Ctype | Access privileges
n8n | admin | UTF8 | en_US.utf8 | en_US.utf8 |
postgres | admin | UTF8 | en_US.utf8 | en_US.utf8 |
template0 | admin | UTF8 | en_US.utf8 | en_US.utf8 | =c/admin +
| | | | | admin=CTc/admin
template1 | admin | UTF8 | en_US.utf8 | en_US.utf8 | =c/admin +
| | | | | admin=CTc/admin
(4 rows)
n8n=# exit
PS C:\Users\najmul> kubectl logs n8n-7bf5986bbb-2trxp -n n8n
Defaulted container "n8n" out of: n8n, volume-permissions (init)
2025-03-18T14:08:43.922Z | ←[33mwarn←[39m | ←[33mPermissions 0644 for n8n settings file /home/node/.n8n/config are too wide. This is ignored for now, but in the future n8n will attempt to change the permissions automatically. To automatically enforce correct permissions now set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true (recommended), or turn this check off set N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=false.←[39m {"file":"instance-settings.js","function":"ensureSettingsFilePermissions"}
User settings loaded from: /home/node/.n8n/config
(node:1) Warning: TypeError
module: @oclif/[email protected]
task: findCommand (audit)
plugin: n8n
root: /usr/local/lib/node_modules/n8n
message: Cannot read properties of undefined (reading 'database')
See more details with DEBUG=*
(Use `node --trace-warnings ...` to show where the warning was created)
task: findCommand (base-command)
plugin: n8n
task: findCommand (execute-batch)
plugin: n8n
task: findCommand (execute)
plugin: n8n
task: findCommand (start)
plugin: n8n
task: findCommand (webhook)
plugin: n8n
task: findCommand (worker)
plugin: n8n
task: findCommand (db:revert)
plugin: n8n
task: findCommand (export:credentials)
plugin: n8n
task: findCommand (export:workflow)
plugin: n8n
task: findCommand (import:credentials)
plugin: n8n
task: findCommand (import:workflow)
plugin: n8n
task: findCommand (ldap:reset)
plugin: n8n
task: findCommand (license:clear)
plugin: n8n
task: findCommand (license:info)
plugin: n8n
task: findCommand (list:workflow)
plugin: n8n
task: findCommand (mfa:disable)
plugin: n8n
task: findCommand (update:workflow)
plugin: n8n
task: findCommand (user-management:reset)
plugin: n8n
› Error: command start not found
PS C:\Users\najmul> kubectl logs n8n-7bf5986bbb-2trxp -n n8n >> log.txt
Defaulted container “n8n” out of: n8n, volume-permissions (init)
PS C:\Users\najmul> kubectl describe deployment n8n -n n8n
Namespace: n8n
CreationTimestamp: Tue, 18 Mar 2025 14:17:36 +0530
Labels: service=n8n
Annotations: deployment.kubernetes.io/revision: 10
Selector: service=n8n
Replicas: 1 desired | 1 updated | 1 total | 0 available | 1 unavailable
StrategyType: Recreate
MinReadySeconds: 0
Pod Template:
Labels: service=n8n
Init Containers:
volume-permissions:
Image: busybox:1.36
Port: <none>
Host Port: <none>
Command:
sh
-c
chown 1000:1000 /data
Environment: <none>
Mounts:
/data from n8n-claim0 (rw)
Containers:
n8n:
Image: n8nio/n8n:latest
Port: 5678/TCP
Host Port: 0/TCP
Command:
n8n
start
Limits:
memory: 2Gi
Requests:
memory: 1Gi
Environment:
DB_TYPE: postgres
DB_POSTGRESDB_HOST: postgres-service.n8n.svc.cluster.local
DB_POSTGRESDB_PORT: 5432
DB_POSTGRESDB_DATABASE: n8n
DB_POSTGRESDB_USER: <set to the key 'POSTGRES_NON_ROOT_USER' in secret 'postgres-secret'> Optional: false
DB_POSTGRESDB_PASSWORD: <set to the key 'POSTGRES_NON_ROOT_PASSWORD' in secret 'postgres-secret'> Optional: false
N8N_PROTOCOL: http
N8N_PORT: 5678
N8N_LOG_LEVEL: debug
Mounts:
/home/node/.n8n from n8n-claim0 (rw)
Volumes:
n8n-claim0:
Type: PersistentVolumeClaim (a reference to a PersistentVolumeClaim in the same namespace)
ClaimName: n8n-claim0
ReadOnly: false
n8n-secret:
Type: Secret (a volume populated by a Secret)
SecretName: n8n-secret
Optional: false
Node-Selectors: <none>
Tolerations: CriticalAddonsOnly op=Exists
kubernetes.azure.com/scalesetpriority op=Exists
Conditions:
Type Status Reason
Progressing True NewReplicaSetAvailable
Available False MinimumReplicasUnavailable
OldReplicaSets: n8n-85db4b8db6 (0/0 replicas created), n8n-5bc69f5598 (0/0 replicas created), n8n-57b499f476 (0/0 replicas created), n8n-67f7d6bcf7 (0/0 replicas created), n8n-94c6868b9 (0/0 replicas created), n8n-8649977478 (0/0 replicas created), n8n-5f589f4775 (0/0 replicas created), n8n-5994b5c849 (0/0 replicas created), n8n-6bf998cd79 (0/0 replicas created)
NewReplicaSet: n8n-7bf5986bbb (1/1 replicas created)
Events:
Type Reason Age From Message
Normal ScalingReplicaSet 53m deployment-controller Scaled down replica set n8n-6bf998cd79 to 0 from 1
Normal ScalingReplicaSet 53m deployment-controller Scaled up replica set n8n-7bf5986bbb to 1
PS C:\Users\najmul> kubectl describe pod n8n-7bf5986bbb-2trxp -n n8n
Namespace: n8n
Priority: 0
Service Account: default
Node: aks-agentpool-17642114-vmss000001/10.224.0.5
Start Time: Tue, 18 Mar 2025 19:01:31 +0530
Labels: pod-template-hash=7bf5986bbb
service=n8n
Annotations: <none>
Status: Running
IP: 10.244.0.161
IPs:
IP: 10.244.0.161
Controlled By: ReplicaSet/n8n-7bf5986bbb
Init Containers:
volume-permissions:
Container ID: containerd://f625582654e0cd4c074c14bb552044804031e41018c573596c4d51f6e1362b7c
Image: busybox:1.36
Image ID: docker.io/library/busybox@sha256:7a5342b7662db8de99e045a2b47b889c5701b8dde0ce5ae3f1577bf57a15ed40
Port: <none>
Host Port: <none>
Command:
sh
-c
State: Terminated
Reason: Completed
Exit Code: 0
Started: Tue, 18 Mar 2025 19:01:36 +0530
Finished: Tue, 18 Mar 2025 19:01:36 +0530
Ready: True
Restart Count: 0
Environment: <none>
Mounts:
/var/run/secrets/kubernetes.io/serviceaccount from kube-api-access-w99k6 (ro)
Containers:
n8n:
Container ID: containerd://884dd12a90346799bf1d008c4f1a8ae9e5677748158ac29d89bb95d81024b74c
Image ID: docker.io/n8nio/n8n@sha256:5288543ac4dc1ea7149a93e38a24989c913c9007dd2459f6c730ac247c4d958f
Port: 5678/TCP
Host Port: 0/TCP
Command:
n8n
start
State: Waiting
Reason: Error
Exit Code: 2
Started: Tue, 18 Mar 2025 19:54:08 +0530
Finished: Tue, 18 Mar 2025 19:54:10 +0530
Ready: False
Restart Count: 15
Limits:
memory: 2Gi
Requests:
memory: 1Gi
Environment:
DB_TYPE: postgres
N8N_PROTOCOL: http
N8N_PORT: 5678
Mounts:
Conditions:
Type Status
PodReadyToStartContainers True
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
n8n-claim0:
ReadOnly: false
n8n-secret:
Optional: false
kube-api-access-w99k6:
Type: Projected (a volume that contains injected data from multiple sources)
TokenExpirationSeconds: 3607
ConfigMapName: kube-root-ca.crt
ConfigMapOptional: <nil>
DownwardAPI: true
QoS Class: Burstable
node.kubernetes.io/memory-pressure:NoSchedule op=Exists
node.kubernetes.io/not-ready:NoExecute op=Exists for 300s
node.kubernetes.io/unreachable:NoExecute op=Exists for 300s
Events:
Normal Scheduled 53m default-scheduler Successfully assigned n8n/n8n-7bf5986bbb-2trxp to aks-agentpool-17642114-vmss000001
Normal Pulled 53m kubelet Container image "busybox:1.36" already present on machine
Normal Created 53m kubelet Created container volume-permissions
Normal Started 53m kubelet Started container volume-permissions
Normal Pulled 53m kubelet Successfully pulled image "n8nio/n8n:latest" in 1.441s (1.441s including waiting). Image size: 201772341 bytes.
Normal Pulled 53m kubelet Successfully pulled image "n8nio/n8n:latest" in 1.392s (1.392s including waiting). Image size: 201772341 bytes.
Normal Pulled 53m kubelet Successfully pulled image "n8nio/n8n:latest" in 1.426s (1.426s including waiting). Image size: 201772341 bytes.
Normal Pulling 52m (x4 over 53m) kubelet Pulling image "n8nio/n8n:latest"
Normal Created 52m (x4 over 53m) kubelet Created container n8n
Normal Started 52m (x4 over 53m) kubelet Started container n8n
Normal Pulled 52m kubelet Successfully pulled image "n8nio/n8n:latest" in 1.388s (1.388s including waiting). Image size: 201772341 bytes.
Warning BackOff 3m42s (x228 over 53m) kubelet Back-off restarting failed container n8n in pod n8n-7bf5986bbb-2trxp_n8n(4f74e1e3-a2c8-4046-9008-b35ae029d255)
PS C:\Users\najmul> kubectl get pods -n n8n
n8n-7bf5986bbb-2trxp 0/1 CrashLoopBackOff 15 (2m7s ago) 54m
postgres-6665f78f5f-2scgl 1/1 Running 1 (5h24m ago) 5h25m
PS C:\Users\najmul>
