N8n self-host is failing
Hi.
My n8n says “disk or ram is full”, and when I open up the DigitalOcean console, i get the following error:
Error: All configured authentication methods failed
Please help with this asap,! thanks
Hi,
Is this a production system? And you maybe able to access inside digitalocean. have you reach out to digitalocean to get access, once you have access we can start cleanup.
btw are you using postgres db? or sqlite? and whats ure server spec?
Can you redeploy a new image, with the n8n data (ie can restore quickly)
Best regards,
Samuel
I’ll be completely honest, I didn’t understand anything haha.
I am pretty new to this, so I really do not understand.
Hey,
No problem, thought to check how urgent it was lol, okay so what workflows did you have? did you make much progress? You need to get access or redeploy just depends if you need the data from it.
Best regards,
Samuel
Pretty urgent yeah, I somehow got 2 clients in just a month, and they both have active workflows under my account.
thanks
The issue is: I tried logging in to the Digitalocean recovery consolde multiple times, but it is just saying “incorrect” login for some reason:
I try using “root” as the login, then my root password which was just reset.
I’m also hosting through digital ocean. How did you configure your instance?. The one they provided is the most flawless one.
Hey Malik, @Malik_Mahjooba
Do you want to jump on a call? We can use a discord channel if you’d like @Grot you up for it too?
Best regards,
Samuel
That is super nice of you!
my discord is : mhj77s
Thanks!!!
