N8N SQL Output
The issue i face up is once i run the nodes, not output return, meanwhile in my prod db, it have values. why is this so?
@Amnan_Sani The reason your SQL ends up with no rows is that the
date(u.premium_start_at) = CURRENT_DATE
condition is very strict and excludes everything. Therefore, n8n displays No output data.
Does it return your product data now?
it doesnt return the prod data. just return no output. i can only fetch data from last 3 days backward. then everything return no output only even the data exist in my db. what my needs for that node is, i want to fetch user data that subscribe to premium from yesterday record.
@Amnan_Sani Change your SQL query to date(u.premium_start_at) = DATE_SUB(CURRENT_DATE, INTERVAL 1 DAY) to fetch yesterday’s premium subscribers.
thank you so much!!
