I had installed n8n on oracle cloud and pointed my domain through cloudflare proxy, i used coolify to deply n8n and do the url and webhook to my FQDN
What is the error message ?
The issue is that if I use telegram bot integration and select the saved credentials it will remain in listening mode and no data show whenever i typed to the bot
I used the simple weather template
- **n8n version:1.7.1
- **Database (default: SQLite):default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):docker
- **Operating system:ubuntu 20.04
