Operating system:
HI Team, I am new to the n8n community. I have business edition set up with docker compose, I want to push the logs to Signoz using otel, I want node level logs with input/output logs , could any one please point me to the right documentation or suggestions please. We are on n8n 2.27.5 Business edition
Hi @Rustrive Welcome!
Node spans carry counts, not payloads. node.execute records n8n.node.items.input and n8n.node.items.output, the number of items in and out, alongside the node id, name, type and version. No environment variable adds the data itself, and the two that do record payloads, N8N_AGENTS_TRACING_RECORD_INPUTS and N8N_AGENTS_TRACING_RECORD_OUTPUTS, cover the Agents feature rather than nodes. Full attribute table:
Node-level custom span attributes accept an expression and would put payload data on the span, but the docs list them as self-hosted Enterprise, so a Business licence will not export them.
On your edition the route is to join the two. The workflow span already carries n8n.execution.id, so send the traces to SigNoz as they are and fetch the payloads against that id:
Nice thread, and Anshul’s routing (correlate trace by n8n.execution.id, then pull the full payload via GET /api/v1/executions/{id}?includeData=true) is the right way to get the actual data on Business edition.
One thing worth planning for once that pipe is built: a span, and even the correlated payload pull, only tells you the node ran and how many items came out, not that the values inside were correct. We hit this exact gap before, a node was returning valid JSON with the right item count but a field had silently started coming back null after an upstream schema change, and nothing in tracing caught it because the shape looked fine.
Two cheap additions once you have payloads flowing to SigNoz: a lightweight schema or contract check on the node output before it counts as a pass, not just item count, and a scheduled known answer probe, a frozen synthetic input run through the pipeline on a schedule with a fixed expected output, so you catch value level drift even when nothing errors and no one is looking at a specific execution.
