N8n workflow piapi problem
Hey i am working on an youtube automation workflow and ive ran into an issue. First when i create text2image with piapi everything works but after that when i try image2video it sends me this error and the second screenshot are the changes i made to the body segment (not sure if this helps)
Screenshot_24
Hi @HemoridenHans
The error message is actually quite descriptive:failed to do kling preprocess request
This might indicate that the issue is not on your side.
Could you check piapi.ai account?
There might be some restrictions on the model itself, your balance, or something along those lines.
Additionally, please review the official documentation for creating tasks with the Kling API:
Finally, if nothing works, please attach the workflow or the node. Someone might be able to help.
