N8n Workflow with Sumopod Trigger Not Returning Expected Output from SQL Database
Hello, I am facing an issue with my n8n workflow using a Sumopod trigger and Wuzapi. The trigger seems to be working fine, and all steps are checked, but when I execute the workflow, it does not return the expected output. I have a SQL database with thousands of items, but no automatic results are generated.
Do I need to fix this by using Neon Cloud and DBeaver for the SQL query? Could someone help me troubleshoot the workflow to ensure it’s returning the correct results?
I would also appreciate any guidance on what might be wrong or if there are any settings I need to adjust.
Thank you in advance for any help!
Technical Information:
